- BurbManExplorer III
gmctoyman wrote:
I did mine mainly for boondocking. Tee into hot water line at galley wit a 1/4" line to the inlet side of the water pump. In that line put a 12v selanoid valve. Control that valve with a remote control on/off switch with 2 remotes, one in the bathroom, one in the galley. Push the button and circulate water from the water heater, back to the tank/pump inlet, count to 20 and water is hot. It can be used on city supply but need to make sure you don't forget that it's on, it will over fill the water tank.
This is what I was thinking. Our WH is at the rear of the TT so the shower is fine but you waste 1/2 gal or so at the kitchen faucet waiting for hot water. If I teed into both hot and cold at the kitchen faucet and connected those lines with a bypass line that had both the solenoid valve and a separate pump with an intermittent contact switch (press and hold for "on").
So pressing the button would open the bypass solenoid and turn the pump on at the same time circulating water from the hot feed at the faucet back through the cold line. Hold button for 20 seconds then release, no danger of leaving it on.
Energy usage would be the same, cold water is still entering the HW heater to replace the hot you are using, the only difference would be that the cold water is coming from what is sitting in the HW line not from the tank. Benefit would be water savings when boondocking with no extra energy cost.
Thoughts? - C_SchomerExplorerIt would work just like old convection hot water space heat and convection radiators and the lines need to be big and have a lot of pitch. Craig
- UnyalliExplorerLeaf-peeper dang nice install.
- ependydadExplorer
Unyalli wrote:
ependydad wrote:
IMO, it sounds like what you win in water usage, you lose in power usage.
You have my curiosity. How would you loose in power usage?
For a power usage, I was going off of the idea that there would need to a pump integrated into this solution. However, reading further posts- I'm not positive if this is the case or not. But it's what I was saying- less hot water, more electric used to run a pump. I think the extra heating of water seems like it would be nominal especially if the lines are insulated in this loop.Unyalli wrote:
ependydad wrote:
Why not look at a dedicated instant hot water faucet?
What are we talking about? Again, curious.
As for a dedicated instant hot water faucet. My in-laws have one that they use to make tea and coffee. Here's one of many (and many at different price points):
InSinkErator Chrome Hot Water Dispenser
The more that I read, this doesn't seem to be what you want. From what I gather, you just want the hot water to be at the top, not super hot water for other purposes. - Leaf-PeeperExplorerHere's some photos of our Hot Water Recirculation system >> Here <<
- motorcycle_jackExplorer II
Unyalli wrote:
Ok, so looking at the picture of my hot water heater plumbing I would install a T in the incoming blue line at the bottom left. Then install a T in the hot water line up near the faucet. Now run a new line between these T's with a one way valve allowing the hot side access to the cold side. Yes?
Yup, you got it. The water in the tank is heated and rises in the feed line and as it cools it falls to the intake port of the hot water heater SO you have hot water at the faucet all the time. You might want to insulate the hot line to the faucet. - UnyalliExplorerThe circulation loop would be the hot line to the faucet then back through a new line to the cold intake of the heater. Insulated this loop would be an extension of the tank and only feed cold into the tank till the loop has hot. I understand this would cause the heater to run a little more but don't believe it would be all that noticeable.
- BobboExplorer III
You are constantly pulling hot water out of the water heater and replacing it with cold water, cooling the tank, causing the heater to cut on more frequently, using either electricity, or propane more rapidly. - UnyalliExplorer
What are we talking about? Again, curious. - ependydadExplorerIMO, it sounds like what you win in water usage, you lose in power usage.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
