SoundGuy wrote:
Vintage465 wrote:
The trailer came with a factory installed quick connect and hose to run tank pressure to an appliance that uses a small high pressure bottle of gas.
:h Any quick connect gas fitting I've seen on any recreational vehicle has always been low pressure, 11" water column or ~ 0.5 p.s.i.
This one came with brass tee upstream of the regulator that had a the same connection type that small propane cylinder has. It also came with hose that has the invert(female)of that connection on one end and the same male connection on the other end that you would connect to the appliance, in this case a Q-1000 Weber gas grill. I've seen it at Camping World last time I was there. I just looked on the web site and can't find it by description likely cause I don't really know what it's called. Coleman makes an 8' long hose just like the one that came with my trailer. Soon as I find it I will post the part # and manufacturer.
