talonhead
Jul 15, 2015Explorer
If you use square alum tube (for base stability), you could put one inside the other and use a small pulley and hand crank to make a telescoping mast. If you put side bars that are a few feet long each, and run small cables to the top and ends of bars (is like guide wires) and maybe a 3rd/4th one to a ground anchor(s). Would depend on height and how stabil you can make it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
