BurbMan
May 06, 2014Explorer III
rsqfyrmedic wrote:
Would LOVE thoughts on this. The hitch was welded to a 1/4" steel bar that's bolted to the frame just behind the thin, stinky slinky-hiding bumper.
1/4" flat steel only at the receiver is not enough to support that weight behind the TT. It's not the weight it's the bounce back there that will tin-can that steel and cause it to fail.
You need to lose the bumper and extend the frame to provide enough support.
Those frame extensions are 1/4" by 2 1/2" angle for rigidity.
We had our Honda 2000 attached to the TT like that and the vibration was annoying. If you are going to travel with them in the truck bed I would just run them there. I travel with the 2000 in that box but put it on the ground now to run it.
Nice fab job though, you do nice work.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
