2500_Grunt
May 11, 2014Explorer
BurbMan wrote:
Here's the build thread on my frame extension.
Using a hitch receiver to make the assembly removable is a good idea, but you need to beef up the attaching points. That back of the TT is subject to a lot of bouncing up and down, so the design not only has to handle the weight it has to control the movement as well.
Link is not working for me? I used receiver tube and welded it to the underside of the frame that was used for the supports then fabricated a rack for mine to sit on then the male receiver tube ends welded to the rack and it slid into the female 2.5" receiver tube under the RV. Altered the TW of my TT too much though. Here are some pics: http://www.smokstak.com/forum/showthread.php?t=89988
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
