rsqfyrmedic's avatar
rsqfyrmedic
Hitch mount generator setup.
Would LOVE thoughts on this. Perfectly houses both my Honda 2000 generators (with parallel kit) and a 6 gal marine fuel tank. Got my grill on top for now but will probably keep it in the bed due to weight. Doing 8300 miles this summer and will spent some time boondocking (ok, we're going to Walmart it when not in parks with full hookups.) DW probably going through menopause and NEEDS a/c. Added a hard start capacitor to the A/C and changed every single light bulb in the rig to LED (including an awning strip--SO cool!) The hitch was welded to a 1/4" steel bar that's bolted to the frame just behind the thin, stinky slinky-hiding bumper. Took it out for a test ride and it definitely affected the handling; going to reinforce the bar and add tongue weight in the form of the spare tire and reassess the handling issue. Will most likely keep the generators in the bed of the pickup for the drive then put them in the cage and connect at the Wally worlds we stop at; figure we'll resupply while the rig cools off and after we get permission from the manager. Oh yeah, going to add reflectors as well:C
Hope to see ya out there!
  • Don't understand the thinking of moving it to run.
    Mine runs fine in the truck bed and the camper cord reaches it fine.
    Maybe I'm just lazy but I don't get it.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Probably would be OK if you did not drive with the box installed, ie, you carried the setup in the bed of your truck and then put it in place when you arrive.
  • Move it to the truck bed that's where I run mine.
    Too much too far back. Looks like a good welding job,though.
    Good Luck, Mike
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,382 PostsLatest Activity: Jul 26, 2025
