jjrbus's avatar
jjrbus
HOnda 2000 extended gas tank
I am experimenting with using auxillary tank to my Honda 2000. I have clear line to see fuel moving and seem to be holding a vacuum.
The info I cannot find is when should the genset start siphoning fuel from the tank and should the vacuum from the fuel pump be measurable?
  • More full the tank is the quicker it starts to draw? That is interesting, I will try and take notice. I have found that as long as there is enough gas to start the Honda it will continue to draw gas.
    Have you noticed how far below the genset the aux tank can be?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 18, 2025
