jjrbus
Oct 14, 2019Explorer
dieseltruckdriver wrote:Me Again wrote:
So oldman and driver, you would rather remove the cover and drain the gas in the carb to where?
The back of my pickup. It is less than a quarter of a cup. It isn't hard, or a big deal and evaporates very quickly. It takes less than two minutes start to finish.
Edited to add:
By draining the carb, you are going to get more gas out of your carb bowl than running it dry. THAT is why I am a fan of draining instead of running them dry, therefore why I think it isn't a big deal.
Me too, have not had carburetor problem in small engines since I started about 5 years ago!
With the Honda 2000 when traveling I will not go out of my way for non ethanol and use ethanol gas. But the last tank through is always non ethanol. I do not use stabil as the non ehtanol has a claimed shelf life of 1 year.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
