opnspaces
Feb 06, 2020Navigator III
I like your switch idea which effectively isolates the fuel shutoff from the generator shutoff.
Some of my thoughts on the eu2000i
I travel with my eu2000i inside my TT sitting on the floor in front of the couch. I never smell fuel when I get to my destination. If you are smelling fuel there is a problem with your fuel cap. It's either not tight enough, or the filler neck sealing surface is not smooth, or the o-rings in the cap are bad.
to prevent gumming of the jet I pull the side cover and drain the bowl if it's going to be in storage for more than a few weeks.
Running the carburetor dry is a misnomer. You are only lowering the fuel level in the float bowl until the jet is exposed. There is still fuel at the bottom of the bowl that will go bad over time.
If I forget to drain the bowl and the carburetor plugs up (loping idle) I spend fifteen minutes and clean it out. Link
If you drain or run dry there is no need to pull the starter rope repeatedly upon next use. Simply turn on the run switch and walk away for a few minutes and the carburetor will gravity fill. Now you're back to 1-2 pulls.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
