Boon_Docker
Oct 16, 2017Explorer III
owenssailor wrote:SAR Tracker wrote:
Here in Central Oregon, we have "emergencies" once in a while. I just run an extension cord inside from the generator to a power strip, running the fridge, freezer, TV, and laptops. Longest I've had to run them is 28 hours. Normally, the generator stays in the garage.
I really hope you shut off the main beaker to your house when you do a jury rigged approach like this. Otherwise you can send 120V power out to the lines where people are working. This could hurt or kill them!!!!!!!!
No need to turn of the main breaker.
You plug the power strip into the generator then unplug the appliances and plug them into the power strip. No way you can send 120v outside the house.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
