OpenRangePullen's avatar
Aug 24, 2013
Horn+High Beams=Better horn
I was thinking of doing a mod to my truck, but wanted to know if anyone has modded their vehicle so when the horn was pressed the horn and high beams would work at the same time. They would work like simultaneously (together). If anyone has done this, how did you go about doing this?
Thanks... :h
  • It is technically illegal in many states to use high beams for communication.
  • using stock high beams would be a waste of time.. Using HID high beams might help..
    but lots of places .. flashing lights mean THET CAN continue.
  • Some people think if you flash your high beams at them that you are telling them to go. Just me, but it might not be such a great idea.
  • I have never done it but you would just need a relay or 2 under the dash depending on how the high beams are wired. If you can pull up the wiring diagram for the steering column we could tell you what to test with a test light to wire it up.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,401 PostsLatest Activity: Mar 11, 2026
