2001400ex's avatar
2001400ex
How do I replace these with LED lights
I'm not the sharpest tool in the shed. I have a 2013 shockwave toy hauler from forest river. I want to replace my bulbs with LED bulbs to reduce the power draw. But I can't get into the bulbs. I pull on the glass and the whole thing just comes down. It feels like it's spring loaded into the ceiling and I can't get the glass off to get to the bulb. I tried a screwdriver to pry it apart but can't get it to work. What am I doing wrong?
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
  • Yeah I've pulled and I'm afraid of breaking it. It just comes out of the ceiling.
  • Looks a lot like mine. That lens should just pull out. It is real tight. Held in with a flat spring type retainer.
    Mine are a G4 bulb.
    Something like these might work for you.
    http://www.amazon.com/dp/B00W1038SS/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=36HHYDB8CCEAG&coliid=IY3QGR26E8B3C&psc=1
  • rhagfo wrote:
    Are you sure it isn't LED already???
    ITC RV Lighting
    I can't get in to tell. But I know when I turn on the switch that has 6 bulbs for the main part of my camper, my inverter fan gets loud meaning there's a heavy power draw.
  • brirene wrote:
    Not familiar with it, but does the cover screw off?
    I can't twist it. The whole thing turns. I also tried pulling on the metal piece in it to see if it was holding the glass in with no luck.
    Seriously can't be that difficult lol.
