SidecarFlip
May 04, 2018Explorer III
Why wouldn't the 120V solid copper wire that supplied the defunct ac unit work for powering the Maxair fan? The wire don't know if it's 12 volts dc in it or 120 volts ac.
I'd trace the wire back to the power source, disconnect it and reconnect it to a 12 volt source to power the fan, Simple and issue solved. Use the existing wire.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
