christopherglen
May 04, 2018Explorer
And make sure you flag the wires as 12 volt only - so the next guy doesn't set something on fire by putting them back into the 120 volt breaker.
Ac wiring black is hot, white is neutral (ground). DC wiring black is ground red is hot (+12). In this case I would use the white as a +12.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
