drsteve
May 05, 2018Explorer
SidecarFlip wrote:
Why wouldn't the 120V solid copper wire that supplied the defunct ac unit work for powering the Maxair fan? The wire don't know if it's 12 volts dc in it or 120 volts ac.
I'd trace the wire back to the power source, disconnect it and reconnect it to a 12 volt source to power the fan, Simple and issue solved. Use the existing wire.
Good thinking. Since there's nothing else on that 120v circuit, you can do what you want with that wire.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
