SoundGuy
May 05, 2018Explorer
SidecarFlip wrote:
The wire is already there, just use it for the intended purpose, intent is 12 volts this time. I think you guys are over complicating an easy task.
How is labeling each wire at each end for what it is and thereby avoiding any confusion later "over complicating an easy task" when it's simply common sense. :h As I said, if it were me I'd just pull +/- 12 vdc from a nearby overhead light and be done with it ... now that's "simple". ;)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
