drsteve
May 06, 2018Explorer
daboognish88 wrote:As I said, if it were me I'd just pull +/- 12 vdc from a nearby overhead light and be done with it ... now that's "simple". ;)
Yea I decided I'm just going to leave the original AC wire alone in case I or someone else ever wants to reinstall AC.
I've tried going from a nearby light but the wire must be damaged somewhere along the line. So I tried to go from an further small wall mounted fan wire but that didn't work either. So yea a lot of these wires seem to be dead. So I guess I have to run new wires after all. I don't know how I'm going to do that because they make it impossible to run new wire. I'm guessing everything was wired up before they put on all of the inside panels and such. :R
Yes, that is exactly how they wire it up. Given that there is no easy access to 12v, I would go with SidecarFlip's idea and just use the existing wire. Label it all clearly, and call it good.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
