qtla9111
May 06, 2018Nomad
daboognish88 wrote:
I got rid of the rotten old AC unit and want to replace it with a Maxxair. Problem is I don't know how to wire it.
Do I have to run all new wire to the battery (or wherever it runs to) or can I use the same wire but convert it somehow to connect to the Maxxair? I suspect it will be hard to run new wire through this ceiling.
The existing wire from the AC says its
12/2 WG, 600 V, (UL), ETTCOFLEX, TYPE NM
I think the AC only ever ran on shore power. So I'm not sure if this will even connect to the RV marine battery.
Any tips?
Thanks.
Thanks for posting this. I have wanted to get rid of that worthless boat anchor that sits on my rv roof.
It noisy, way oversized for my small TT so you're constantly frozen out, and it creates that obnoxious humming-vibrating feeling inside the rig.
I was thinking of just having a dome but the fan sounds much better.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
