Cummins12V98
May 06, 2018Explorer III
SoundGuy wrote:As I said, if it were me I'd just pull +/- 12 vdc from a nearby overhead light and be done with it ... now that's "simple". ;)daboognish88 wrote:
Yea I decided I'm just going to leave the original AC wire alone in case I or someone else ever wants to reinstall AC.
I've tried going from a nearby light but the wire must be damaged somewhere along the line.SoundGuy wrote:
That makes no sense - if the light works there has to be +/- 12 vdc at the light so just tap off that source.drsteve wrote:
It's probably a switched circuit...
So turn the switch on and control the light itself with it's own switch, if doesn't have a switch then replace it with one that does.
When I tapped the light wire it was for a light that was a switchable one and the wire had power all the time.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
