daboognish88
May 06, 2018Explorer
Correction: my motorhome USED to have a furnace but no longer does. I thought it was run off 110 volt shore power but it actually runs off the house battery. I just noticed too that there is no wire running the lights from the 12 volt fuse box. Its missing.. at least at that spot.. and there is no fuse and one of the prongs for the fuse holder is broken. I thought I recalled at least one of the lights working at one point when I got the van which leads me to wonder if the previous owner just wired the lights to the furnace fuse when original light fuse holder broke. I'll have to investigate. But seeing as how the light fuse prongs are damaged I should probably get a new fuse box first anyway.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
