May 07, 2018Explorer II
The vehicle frame is ground. The battery negative connection is bonded to the frame. There is no need to run the ground wires back to the fuse panel. They are connected to the frame at a convenient location to reduce line length. This applies to the 12VDC side only. 120VAC is different. All three wires on an AC circuit will return to the panel.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
