FWC
Mar 31, 2021Explorer
The DIY LiFePO4 battery is a great way to go if you are:
(i) somewhat handy and understand the basics of electricity and electronics and
(ii) enjoy a DIY project.
Some useful resources:
LiFePO4 Cells are plentiful and probably cheapest on Alibaba and Xuba seems to be a company with a decent track record:
Shenzen Xuba
They are also available on Amazon:
Amazon 280Ah LiFePO4 Cells
There is well supported and easy to use bluetooth enabled BMS available from Overkill Solar:
Overkill 120A BMS
Also available for much less from the manufacturer:
LLT Power the OEM for Overkill Solar BMS
Shenzen Xuba
Overkill 120A BMS
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
