StirCrazy
Mar 31, 2021Moderator
theoldwizard1 wrote:
For those on a budget, these weed grade B cell and the author did make "studs" to use on the screw in terminals that were not in the best of shape. Cheap fix !
After the build, it was tested successfully to full capacity.
I would recomend making studs for the "A" grade also. the thread depth isnt that deep so when you start hooking stuff up its nice to have that extra lenght so your not striping the top threads out.
Steve
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
