pianotuna
Mar 31, 2021Nomad III
StirCrazy wrote:
Ok so why is the video flawed?
From your first post:
this video is pretty decient on how to do it, what is missing is some sort of case. the Prismatic cells like to be clamped togeather slightly if you going to be running high currents. I have seen cases made out of wood with threaded rod providing the pressure, and several other ways also.
also I am not a fan of the BMS he uses, there are lot better ones, but he explains he needed the high capacity one to do a torture test on the cells.
280Ah LFP build
Your words. I find your comments are often flawed. I'm sure you feel the same way about mine.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
