Freep
Apr 06, 2021Explorer
theoldwizard1 wrote:
For those on a budget, these weed grade B cell and the author did make "studs" to use on the screw in terminals that were not in the best of shape. Cheap fix !
For any of the prismatic cells I highly recommend installing studs and securing them with loctite. The aluminum they use for those terminals is VERY soft and it's easy to strip them out. Even with the studs you want to be careful not to over torque.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
