FWC
Apr 07, 2021Explorer
otrfun wrote:
Overkill BMS's seem to have a very good rep; however, to my knowledge they don't make BMS's larger than 120a. For those who have 2000-3000w inverters with 200-300a current requirements what options do they have? Daly makes a few 150-250a models, but they have a somewhat sketchy rep. I suppose one could parallel multiple Overkill 100-120a BMS's and LifePo4 battery packs.
Running several in parallel is not a bad idea, it would be the same as running several drop in batteries in parallel. It spreads the load (and heat) across multiple devices, and provides redundancy as well. On the down side, you would need to look at several screens on the app to see what each pack is doing, but that is not a huge deal. If you are handy you could also merge the data from each BMS into one stream as the protocol is open source.
To give credit where credit is due - these are not Overkill Solar's BMS, they are just retailing/rebranding LLT powers BMS.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
