FWC
Apr 07, 2021Explorer
time2roll wrote:
I plan to use two Overkill BMS on two parallel batteries. 240 amps continuous. I believe Overkill will surge 130 to 150 amps for a few seconds.
You can program the max current and duration on the LLT/Overkill. 150A for a few seconds should be fine as the problem is heat dissipation in the MOSFETS. You could even add a better heatsink if you need to do higher currents often.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
