StirCrazy
Apr 09, 2021Moderator
pianotuna wrote:
otrfun,
It may be an issue if the batteries are connected in series to create a 24 volt bank. This means using six volt jars may be not recommended.
For parallel they need to be connected in a balanced manner.
a 24V battery is no issue, you would make one battery using 8 cells and a 8S BMS. it is designed for a 24 volt battery. they also make a 12S and a 16S BMS. so if you want to buy the big step down converter you could make a 280AH 48V battery and use that.
Steve
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
