StirCrazy
Sep 27, 2021Moderator
time2roll wrote:
I put the 2x Overkill BMS and some fuses on a small shelf in the box. This is actually two separate batteries. Each has 2 cells in parallel and 4 in series so 8 cells per battery.
I expect to get this into my front compartment next weekend.
I like that setup. only questions I have is the use of the rachet strap and the potential for the hooks to damage the side of the battery cell. and I cant see any isolater between the cells. if the rachet strap is temporary how do you plan on compressing the cells to get better life out of them or are you, not worring about it as the charge rater will be lower than .25C and no risk of any heat?
Steve
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
