BFL13
Oct 05, 2021Explorer II
Looks like you can handle whatever happens--well thought out set-up!
You need to do your hot water line trick again to put a hot water line by the battery bank, and heat that water from the furnace exhaust now being wasted to the outside air. :)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
