time2roll
Oct 06, 2021Nomad
Itinerant1 wrote:Heaters will be wired on the load side of the BMS. If the load side is powered by generator, solar or vehicle, the power will go to the battery heater.
If the heating pads are wired directly to the batteries terminal and if needing them because the actual cells are below 32f and not the ambient temp how would a generator help unless you have a heater cube plugged into it throwing heat to the compartment.
Are you going to add extra insulation on the walls/ floor to help keep heat in and cold out during the colder months if using them during that period?
Insulation will not be added unless it seems to be needed. Most camping is in fair weather. Not intended to be a north pole expedition vehicle. Just some minimal protection for a mild cold snap.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
