BFL13
Oct 06, 2021Explorer II
time2roll wrote:
I do wonder if these self heated batteries only allow external power for heating.
Should still be able to keep them warm with heat pads, etc. Only then use the charger heating method as an emergency back-up.
I see I forgot the actual Trillium charging specs. They do allow a little charging a little below freezing, but also only allow full charging at 73F. No clue how that may apply to other LFPs.
https://www.trojanbattery.com/pdf/Trillium_UsersGuide.pdf
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
