time2roll
Oct 25, 2021Nomad
No. The heaters did not come on. Set to on 40, off 45. I did test the system with an ice cube before attaching the sensor to the battery. Collectively just under 6 amps was moving evenly through the heaters giving about 60 watts of heat. No power source at that point so no temperature rise verification or performance was measured.
I assume it is good to 20f, maybe lower, and covers about the worst I would see. Could be they never activate. Glad to know they are there to buy some time so as not to create an immediate panic to roll out.
Not really an expedition vehicle. Not likely to be in Canada in winter.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
