Mello Mike wrote:
I like your idea of using silicone adhesive. My LEDs came with velcro tape. They seem to be holding up well so far, but I have doubts once the temps here hit the 100s.
LED Retrofit and 12v Outlet Installation
Yeah, the LED panels actually get fairly warm in use... add the heat from warm weather, and the adhesive on the factory double-backed foam tape softens and turns loose. The foam tape might work better on a flat surface, but I have these LED panels applied to the convex reflectors of my light fixtures -- so just the edges of the tape are doing anything.
I tried hot melt glue, but some of those panels eventually came loose also (especially the porch light which is exposed to sunshine). I think this blue silicone adhesive will do the job, but if it doesn't work out I'll buy some high-temp silicone. The nice thing about silicone is you can peel it off if you need to change out a panel.
