Well I received my order of the Chinese manufactured LED units 2 days ago and have started the transiton. Installed all of the "bulbs" and am now working on converting the floresent fixtures using the 36 panels. Put 6 panels into the floresent bathroom fixture and there should be no excuse of missing the loo! Unless you look at the light first! They are real bright and maybe too beight for the bathroom., but they work great. Discovered that I hadn't ordered a LED for one of my smaller bulbs (only one in trailer - inside step light) so I broke the glass on the bulb and soldered a LED push-in bulb into the base... and it worked! Someone noted earlier that they thought these led units may be polarity sensitive, and the are! So be aware, if they don't work when you first install them, you may have to "turn them around" so to reverse the polarity (the push-in bulbs anyways). So far all is much better than expected, and you can't beat the price.
