Joeyo67 wrote:
For you electricians out there, can I add solder to these two contact points to create a center contact for the socket? I realize I would have to make certain that it would have to be the same hight as the other two contact points at the bottom so it will fit. But not 100% if this will work.
Please let me know!
The short answer is no. The bulbs with 2 contacts have the LEDs wired between the contacts while the single contact bulbs have the LEDs wired between the contact and the base. You received the wrong bulb, probably because you ordered the wrong bulb.
I have seen several posts where people have received single contact bulbs for their double contact sockets. Maybe you can get together and arrange a swap. :h
