kenreef wrote:
Can anyone tell me the pros and cons of the regulated or un regulated on the 1020 and 5050?
Is the warm color the same on the 1020 and the 5050?
Thanks in advance and great information in this post.
In theory the regulated lights should not change when the voltage changes. There have been reports that some of the regulated leds have caused radio frequency interference (RFI). Some of the un-regulated panels have had problems with the solder connections failing and causing a row of 3 leds to go off. I am not aware of any regulated panels.
Color varies from manufacturer to manufacturer. Buy one or two before you buy several to make sure you get what you want.
I am not aware of a 1020 led, maybe you are thinking of the 1210???
