kenreef wrote:
Thanks tenbear
You are correct as I am not sure where I got the 1020. So there is no concern with the un regulated having problems lets say between 11 - 14v? I guess that would be normal operating voltage when charging etc. I was looking at the 1pcs BA9S/921/Festoon(31~44mm) Dome Bulb Warm White 36-1210SMD LED Super bright from 2211_led. I believe I read that you have used bulbs from them somewhere in the 20 pages. Should this color temp be close to the 921?
The 5050 LED's produce three times more light than the 1210's on paper (15 vs 5 lumen). I tried the 20-5050SMD boards and they are almost exactly the same light output as the 921 lamp both on paper and eyeball. The super bright might be too blue for my taste so I ordered warm white to more closely match the color of the 921 lamp. The boards I have are slightly whiter than the 921's even though they are advertised as warm white. I have ten 48-5050SMD LED boards ordered which I will combine with the 20 LED units to give more light. I bought the 48's on
eBay from another China vendor. I'll also be trying some 18-5050SMD units
herefrom seller eversalellc located in USA but product is also from China. I'm really curious about
Thesevoltage regulated boards. Does anybody have experience with these? I'm concerned about the RF interference with the TV and stereo system.
