RVcircus's avatar
RVcircus
Explorer II
Sep 06, 2016
How to make a cordless drill mount for the RV
Well, after a few years of digging through the toolbox for my drill every time we setup and breakdown camp I finally got sick of it. I needed to find a way to keep a cordless drill handy for putting the stabilizers up and down. I wanted the drill in the same place each time I needed it and I don't think that's asking too much.
I've been planning to add some basic drill mounts to the workbench at home and was leaning towards a basic PVC mount that a lot of YouTube woodworkers have done. So for this project I started with that idea and added a few features to make it roadworthy.
Here's a list of supplies and tools I used for this project:
* Short (7-8") section of 3" PVC pipe
* Old piece of thin shock cord/bungee cord
* 1/2" thick piece of foam (floor mat)
* Contact cement (I use Barge cement)
* Paint
* 3/4" wood screws
* Drill
* Dremel
* Jig saw
* An old drill to keep in the RV
Once you have the materials together the build is pretty quick and easy. It took me less than an hour to get it together and painted and I was winging this build (like most of our other stuff). Checkout the below video to see how I did it and I've included steps below just in case you need them.
https://youtu.be/eE7IMU_pHNI
Step 1: Cut a section of 3" PVC to length.
Step 2: Cut the slot to the handle to fit it. Make sure the trigger rests below the bottom of the PVC. I used a jig saw to rough out the shape and a Dremel to smooth it out and tweak the shape of the opening.
Step 3: Drill 1/4" holes on the side to attach a piece of shock cord. This will hold the drill in the mount when driving down the road.
Step 4: Heat and flatten the top of the PVC. I wanted a flat area to mount this to avoid having the weight of the drill shake the screws loose.
Step 5: I used contact cement to attach a 1/2" thick piece of foam to the inside top of the mount. This was to stop the drill from jumping up and resting on the trigger while the shock cord pulled the drill forward into it.
Step 6: Paint it a pretty color. There's nothing better that a flashy tool holder, so I went with black. I used black Plasti Dip for that extra bit of bling, but feel free to use any color you want as long as it's black. I think Henry Ford was onto something there.
This was a simple and cheap project that served a well needed purpose. Have you done something similar or have a better idea? Post it below.
  • mgirardo wrote:
    A cordless drill with several bits, including a square bit is about all the tools I travel with in the RV. Almost everything in the RV can be serviced with just a few bits.
    Nice work as always.
    -Michael
    With a somewhat old trailer and older truck I always seem to need the tool I don't have. It doesn't stop me from trying to bring them all though:B
  • RedRocket204 wrote:
    RVcircus wrote:
    Pops wrote:
    Pictures would be nice.
    Ooh, got the video.... thanks
    When I shoot video I always forget photos. Apparently my brain can't handle both;)
    All video is is a bunch of pictures. Just find an app that can extract pictures from your video and you'll have both.
    Good idea, I've been taking screen shots on my video in a pinch. Thanks for the tip!
  • A cordless drill with several bits, including a square bit is about all the tools I travel with in the RV. Almost everything in the RV can be serviced with just a few bits.
    -Michael
  • nineoaks2004 wrote:
    Great idea, looks good too, Thanks for sharing happy camping
    Thanks! I'm excited I won't need to dig for a drill anymore.
  • Pictures would be nice.
