DrewE
May 31, 2015Explorer III
For towel bars, I made up some backing plates of thin (1/4" or 5mm) plywood that I glued to the surface of the wall, and then used typical plastic expanding anchors that went through both the wall and the backing plate. The glue is mainly to keep the plates in place during installation, rather than as a primary means of support; the plates serve both to help distribute the stresses on the wall (i.e. help keep the towel bar mounts from puncturing the wall material) and add enough thickness to let the anchors grip properly.
Easing the outer edges of the plates with a chamfer bit in a router and painting them with enamel, they look something like blank electrical switch plates under the mounts. So far it seems to be working very nicely, but I don't have enough use on them to give a long-term report.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: May 28, 2026
