mighty7sd wrote:
I tried rivets, but they just pulled right through the thin wall, I think they are really intended for sheet metal. I finally found the smallest toggle bolt I could and it works great! http://a.co/h0EzL2R
At least in my bottom of the line RV there is no foam in the interior walls, so no issues.
Did you use an RV Oscar rivet tho? An ordinary "pop" rivet will not work unless you can get behind the wall surface and put a washer on the rivet first. An Oscar rivet has high holding strength and you normally shouldn't be able to pull one out through 1/8" luan plywood.
