DrewE
Aug 20, 2020Explorer III
Typically I believe they're +12V signals.
If you use a SPDT switch for the wire, with the common going to the head unit and one contact going to the existing circuit, you can connect the other to +12V and see if it works. If for some reason it doesn't, just reconnect the new switch lead to ground instead...or try ground first and change to +12V if that doesn't work.
Hopefully, the camera itself isn't powered only when the reverse lights are on....
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
