bgum
Aug 20, 2020Explorer
Remove hot wire from backup hot wire and move it to tail light wire. It should then work when your tail lights are on. I just wonder if you have it wired to both will it activate with either reverse or tail lights.
Some systems don't wire to reverse signal but to backup lights. They get power from hot and ground in the clear backup lights. Or from running lights hot and ground. I have installed 5 or 6 backup cameras and always wires to reverse lights.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
