RVcircus
Mar 16, 2016Explorer II
Old-Biscuit wrote:
New brakes are VERY easy when you buy whole assembly
4 bolts and 2 wires.....install drum/set bearing preload and manually adjust brakes
I couldn't watch past first wheel removal.........no jack stands used so I passed on viewing further. Not good safe work practices being used.
I agree on the ease, but disagree on the safety. The trailer is hooked to the truck on the Rapid Jack. The jack is being used how it's intended.
If I was using a hydraulic jack I'd use jack stands, but not with this type of jack. The trailer can't move forward or backwards and would have to crush the jack to come down.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
