Old-Biscuit
Mar 22, 2016Explorer III
3/4" NPT steel nipple 6" in length works as a thread chaser
1/2" brass one works for Atwood also....aluminum threads
Simply start the nipple in drain hole by hand then using pliers/channel locks work the nipple back/forth a little at a time until nipple is seated as NPT threads are 'tapered'
Then remove and rinse/flush
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
