Lynnmor
Mar 23, 2016Explorer II
RVcircus wrote:byronlj wrote:
For cleaning up large pipe threads for which I don't have a tap, I use a steel nipple and cut 3 grooves evenly spaced and parallel with the pipe across the threads. I use a cut off wheel in my portable grinder and only cut thread deep. This gives it a cutting edge and a gap for material to collect. Works just like a tap.
Dave
Interesting, I'll need to give that a try sometime. I've used a nipple to cleanup threads that weren't too bad, but have never seen one turned into a makeshift tap.
You did it right the first time. The soft metal of a pipe nipple will mold to the water heater threads and not produce a good thread. You can get a tap that is good enough on Ebay for $10 to $15. Someone not skilled with using a tap could easily damage the threaded hole, so explain that the tap must be run in as far as possible by hand before using any kind of tool.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
