Cummins12V98
Dec 21, 2015Explorer III
SkiSmuggs wrote:
My issues with the Trail Aid Plus are the bolts on the bottom to help prevent sliding mess up concrete or asphalt driveways and create a place for water penetration followed by cracks from freezing. You have solved the problem with what looks like Hoss Pads underneath the Trailer Aid.
Also, I've had cases where it didn't provide enough lift and the pads resolve that also.
I always used the pads since my suspension had so much travel. But if I did not need the height of the blocks I would have just removed the bolts.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
