GrandpaKip's avatar
GrandpaKip
Explorer II
May 11, 2020
Andersen hitch
On another thread, it was posted that the Andersen hitch is not a weight distribution hitch and should not be used on a vehicle that requires one.
When hooked up without it, my truck drops 2” in the rear and raises about 1” in front.
When hooked up with it, the front is within 1/4” of unloaded and the rear is down 1”. This basically levels out the truck, which sits tail high when unhitched.
I’m pretty sure that weight was put back on the front axle, removed from the rear axle and some was given to the trailer axles.
I’m also pretty sure that is what a Weight Distribution Hitch does.
I’m just posting this for the possibility that others contemplating getting an Andersen might be mislead by someone who more than likely has never used one.
My camper is 5000# loaded with a 600# tongue weight. Sometimes more, sometimes less, but it seems like that’s a pretty good average.
If we ever go to a heavier rig, I’d probably change the WDH. We’re very happy with our present setup, so I really don’t see that happening.
