Mont_G_J
Dec 10, 2013Explorer
Only need to add a switch if you want low and hi air conditioner fan speed. I run mine on low (orange wire connected) and like it just fine that way.
I don't see anything in your post that reflects incorrect wiring. Perhaps your next step should be to check for voltage on the orange wire.
Here's a good set of instructions to double check your work: CLICKY FOR HUNTER T-STAT
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
