Chris_Bryant
Dec 11, 2013Explorer II
Just to clarify, the analog DuoTherm units (no longer available), switch grounds to activate the relays in the rooftop unit. Coleman /RVP units switch +12 volts to activate relays. Also, as I said, the orange wire turns the fan on, the blue toggles between high and low. If you just ground the blue, you will not get any fan operation.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,421 PostsLatest Activity: Sep 24, 2026
